Just bought a R8500 and having huge issue
wsarahan
Guys how are you?
I bought the R8500, when I finish configuring it or even when I'm making changes and the router reboots the wan light becomes just red and I can't do nothing..... The only way to the router come back to life is a hard reset, and it happens again and again
I'm with the latest fw from the site 1.0.2.106
Anyone already saw that? What should I do?
Guys how are you?
Try to upload firmware using TFTP:
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
Voxel.
Hardware configurations are almost the same. Software support by ASUS (and availability of Merlin's builds) is better.
Voxel.
Voxel thanks so much for helping
I have only one more question
Testing the Rt-ac5300 and the R8500 the 5Ghz range was very low, they had the same range I can say, is there any way at the configuration that can make my 5ghz range goes better or if I already tried with 2 routers and the results was the same is something related to my house or wifi interference with neighborhood?
Tks again
Tks again
You can try general tips/hints from NETGEAR, like:
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
But my opinion is that if you want good range and coverage you should use additional APs. Minus of this is that it requires additional investments (money) :)
Voxel.
