Yeah I came across that one as well but no answer to it.Only thing I could find this was this post....older post regarding 384.8 when someone else had same issue. Checked a couple pages and didnt see anyone answer though.
https://www.snbforums.com/threads/asuswrt-merlin-384-8-is-now-available.50189/page-21#post-450091
Did yours have a reboot message as well?Yeah I came across that one as well but no answer to it.
Nope.Did yours have a reboot message as well?
Nobody can, because that error message comes from a closed source proprietary component from Broadcom.
Sounds like a memory leak - as you mentioned, likely in one of the closed source components - might be Broadcom, could be some of the Asus or third party items.
As I said above, these links don't answer the question itself.Strange search function, there have been posts on this topic before.
here
https://www.snbforums.com/threads/r...384-11-is-available.56501/page-22#post-490423
and here
https://www.snbforums.com/threads/r...12-is-now-available.57220/page-23#post-502724
Same issue with 384.13 apparently something Asus should have isolated and solved..... For me theses errors cause a reboot which makes the AX88U actually an expensive useless piece of crap.As I said above, these links don't answer the question itself.
It's definitely Broadcom. rdp_fpm.ko is a kernel module that's part of their HND software stack, related to their Packet Runner traffic accelerator (think "next gen" version of their original Flow Accelerator, which provided acceleration at the switching level, if I remember correctly).
I don't have an HND based platform on hand, but I assume there's a WebUI function to disable the flow acceleration stuff, at least for debug purposes.
Maybe that's why I don't have real issues with this log entry. I have QOS bandwidth limiter enabled which disables the two acceleration methods by default. So I have zero acceleration on my AX88U. I get the message every now and then, so no big deal.There isn't. For some reason Asus didn't implement a setting similar to the one they had to disable CTF on previous platforms.
Just ignore it. It has nothing to do with the router's hardware.
Welcome To SNBForums
