Kill switch VPN AsusWRT
qwerty25
Hello
I just purchased the TUF-AX3000 V2 router.
I need to configure a Surfshark VPN to protect all my equipment.
I managed to do the manipulation and everything seems to work.
However, when I cut the VPN on the ASUS router, my equipment automatically switches to the WAN of my original router.
This is a big security issue, because it would mean that if my VPN fails in any way, my network will no longer be protected.
I saw that ASUSWRT Merlin had a kill switch option however I believe the firmware is for the TUF-AX3000 and not the TUF-AX3000 V2 (I'm really disappointed).
I tried to disable NAT from the VPN configuration but my devices no longer have internet access.
Is it possible to configure a kill switch on basic AsusWrt by any possible way (routing or others...)
Cordially,
