I have an odd or out of the ordinary networking problem. I have a computer in my shop that runs a CNC machine. This computer has a wireless card that connects to my wireless router in the house for file sharing and internet. This computer also has a LAN port enabled that is connected to a wireless router (by a cable) that has no internet connection and is set to "On Demand" and is used only for a wireless remote (iPod Touch) that can control my CNC machine with an app.
The problem that I'm having is that when trying to access the internet, it's as if it doesn't really know where to go and will generally time out and not go anywhere. At other times it will go somewhere and then quit again. If I disable the LAN, essentially disabling my wireless remote functionality, it will work fine. I tried bridging the two, but then the wireless won't connect anymore.
Is there a way that I can direct all internet requests through the wireless card and still leave the LAN enabled so I can use the iPod Touch remote as needed? This is on a XP PC.
Thanks,
Scott
Thanks,
Scott
