LAN is crashing without internet connection
Neorun
here is my hardware setup:
-Cable Modem (Unitymedia Germany)
--Ubiquity Edge Router lite
---TP-Link TL-SG1016DE
----Hue Base
----Ubiquity AC Pro
----Devolo 1200 Base
----TP-Link TL-SF1016DS
-----Multimedia Set: Shield TV / Sonos Connect / Philips 7601 / PS3/ Xtreamer Prodigy / Fire TV / Apple TV…
----TPLink 8 Port GB Switch
-----Synology Disk Station
----- Mac Pro
----- HP Network Printer
The Ubiquity Edge Router lite is set as DHCP Server. My plan was to have a stable LAN-network to be able to work with or without internet. Currently my cable company has a few issues resulting in a internet connection loss.
The wired thing is that when I loose the internet connection the network itself will kind of collapse as well…
The Shield TV is not able to see the Synology any more. Same thing with my Laptops. Since the Edge router is handling all the DHCP this should not be an issue - I thought.
The access to the modem is set with a static ip.
I am confused…
Is there any setting that I might have messed up that would result in that scenario?
