Ethereal_Dragon
Hello all. To start out, I wired my home myself with both Coax and Cat5e due to issues with the existing wiring. There are 7 runs total, each consisting of 1 coax, and 3 Cat5e terminations. All of the runs terminate to a network rack I have in the crawlspace, where all of the hardware is centrally located.
I have AT&T U-Verse service, VOIP, internet, and TV, all of which are IP based, which is in part the reason for the number of cat5e runs to each room. The line comes into the house, and goes into the U-Verse Residential Gateway. VOIP splits here, and goes into one of the patch panels, which is cross-connected to the other 7 neighboring ports and short patches connect 2 ports to take the dial tone from the RG to each Red wall socket. IPTV and Data leave the RG on one of the LAN ports and plug into a D-Link DGS-1024D Gigabit switch. The switch then has patch cords that connect each port to a patch panel port to be taken out to each of the 21 wall jacks. I also have the DVR and a NAS in the rack.
That is how the network has been for about 2 years without any issues. Recently, I purchased a new Sony Bravia 46" TV that connects to the internet, and then there is a Wii, a PS3, and the U-Verse set top box connected to it. To remedy the problem, I found a REALLY cheap Linksys BEFSR41 wired router. The router has the most recent firmware version installed, and I logged in and set it up to disable DHCP, made sure the IP address is in the same subnet (I know, it's only for the management interface, not for the switch, since a switch doesn't care about layer 3).
The PS3 was connected to one of the wall jacks, as well as the Linksys router (switch). The TV, Wii, and STB all connect to the Linksys. All will remain fine and dandy for about 3-4 days, and then problems pop up. The trouble is noticed with the TV. There is hitching in the video and audio, artifacts on the screen, and other stuff. None of the other STB's are having issues at the same time. If I unplug the Linksys, and plug the STB directly into the wall, trouble is gone.
When the Linksys is plugged in, all of the activity lights are blinking non-stop. I am wondering if perhaps there is some kind of issue because the 2 switches are directly connected. Does anyone know what this could be? I am wondering if perhaps I move the jumpers at the network rack so that the port that the Linksys is attached to connects to the RG rather than the switch in the network rack.
Any ideas?
Thank you!!!
Here is the hardware involved:
D-Links DGS-1024D:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817111031
Linksys BEFSR41 ver 4.3:
http://www.linksysbycisco.com/AE/en/support/BEFSR41
My Network Rack:
Any ideas?
Thank you!!!
D-Links DGS-1024D:
My Network Rack:
