LAN NTP
Rturnock
I did a lot of searching here and with Google but never hit on a solution but lots of people with the same issue. Apologies if I missed a solution.
The router gets time through NTP perfectly but no machines on the LAN can, including PCs (W7, 8.1 & 10), iPad, Mac. I tried opening port 123, no firewall, port trigger, port forwarding and also going back to reset.
RT-AC68U, 380.57 (and the November firmware).
Are you trying to get NTP time from the router or an external NTP server?
Unless you explicitly block outgoing NTP packets, the traffic should pass just like anything else.
