LAN-port instead of switch before WAN port (AC68u, Merlin 380_63.2)
legrand
First router serves some public computers in a DMZ. One of the cables runs to another apartment to an AC68u (WAN-port). After the AC68u follows the internal network.
-> (wan)router(lan) ---> switch1_DMZ ----------------> switch2_DMZ -> (wan)AC68u(lan) ---> internal
To add a shared host belonging to DMZ but physically next to the AC86u I simply added a switch (switch2_DMZ) before the AC86u and attached it to this switch instead of the AC68u lan port.
Works perfect, but I wonder if I could spare the switch2 and use one of the AC86 LAN-ports for that purpose: Have one of the lan ports acting exactly as the ports on switch2_DMZ
Is there an easy/safe way to realize that?
I don't think you can assign a port a DMZ, but you can assign an IP on the 'AC68U. Don't know if it will work or not, but easy to try.
from the AC68u's view the switch2 is simply the EXTERNAL (WAN) side. I mentioned the DMZ because I wanted to show the whole picture.
My question basically is: can I treat a lan port on the AC68u as a 'pass-thru' of the WAN port, i.e. have it behave the same way as a port in switch2 (in order to omit switch2 to save some electricity)?
