Algimantas
Hello everyone.
I have a question about a network setup that I want to adapt.
My ISP provides internet and IPTV which comes from tagged VLAN6.
VLAN6 is then switched from my router to a IPTV STB which then connects to tv via HDMI cable.
The problem with this is that with this setup my tv's are offline. In order to connect them I can use either ethernet cable or wifi, but wifi signal near both of my tv's are weak so that's not an option. If i decide to use ethernet cable to connect my tv's then there will be a lot of hassle with the cabling.
Is it possible to deliver both VLAN6 and access to LAN via one port to another router which then splits vlan6 and delivers it to IPTV STB while other ports deliver access to LAN for tv's?
The reason I want to connect tv's to the LAN is that I want to watch content that is stored in the NAS.
For a better understanding of the situation, here is the visualization of the network that I want to make
