LEDs on/off schedule
TheLyppardMan
It should be working, I don't see any weird things.
Maybe the following makes a difference? In the Asus Advanced Settings section I have:
Administration > System > Disable LEDs : Yes
Also:
reboot your router. You can confirm that the jobs are properly set up by running the following command through telnet:
cru l
You should see both scheduled tasks listed.
I tried this. It's not working for me on my 86u running 384.13.
I wonder if it has something to do with the permission issues of .45717?
I'm running 384.13 too.
I don't know what you mean with "permission issues of .45717"
All I have done is setting the permissions like this:
chmod a+rx /jffs/scripts/services-start
chmod a+rx /jffs/scripts/ledsoff.sh
chmod a+rx /jffs/scripts/ledson.sh
Bear with me...I'm a user, not a coder. With the release of .45717, there some script permissions are getting reset? For example, after a reboot, you have to reclassify QOS priority, when running the JRFresh QOS script.
BUT, I only did the chmod on the services-start script -- not the ledsoff & ledson. I'll give that a try!
Let us know if that solved it , because if it has then the wiki page need a little update ;)
Wow, I didn't realize that nonsense got carried-over to Merlin 384.13. If so, you need to chmod all executables (scripts and binaries) in /jffs (and sub-directories) after every boot. It is supposed to be fixed in next release - if they ever get one that's stable.
Actually, I've just discovered that I made an error in my opening post. It's not the power led that doesn't come back on; it's the LAN led. All the other leds resume normal operation.
Has anyone tried scheduling the LEDs on either an RT-AX88U or RT-AC88U to see if the same problem occurs, i.e., the LAN LED fails to come back on?
Update: Just tried it again on a new RT-AX88U and despite following all the above instructions, the LAN led still fails to come back on.
Did you do this and reboot?
EDIT—never mind. I see that only the LAN is not working. I have no idea.
Yes, I did do that. I wonder if anyone else is seeing the same issue?
Is it any different to that contained within the link I quoted (the top solution that is, with the two scripts)? I can't see any difference myself, but maybe I'm missing something.
Since the first method is clearly not working properly with my RT-AX88U router, would it be worth trying the second method? If so, can you tell me what exactly I would have to put in the services-start file? Also, would I just create a file called "ledcontrol" and then copy and paste in the code shown on the Wiki?
