Let DHCPv6 advertise so called temporary IPv6 address
neuen
By default stateless IPv6 configuration derives right part of IPv6 address from MAC which is considered a risk allowing to trace the user.
If I understand right this can either be fixed on every client side (in some OSes by default, e. g. Mac OS X; in some OSes needs specific configuration, e. g. Fedora) or globally on router side (via send temp-address; in dhcp6s.conf).
Current version of dhcp6s in AsusWRT-Merlin does not yet support send temp-address.
Am I right?
Do you think it's a good idea to enable support for send temp-address?
