DigitizedMe
Hopefully this is a quick one, and there's a config or script in JFFS I can modify to customize Let's Encrypt to pull both ECDSA and RSA certs, or just RSA? Then I can use RSA in my ipsec.postconf, insead of the ECDSA located in the in the /jffs/.le/hostname_ecc directory.
Now that Let's Encrypt is pushing ECDSA keys, I can't get Android's built-in VPN to connect to the server. The Android strongSwan app works fine! From everything I can tell, the Android IPsec implementation doesn't like the Let's Encrypt ECDSA SHA-364 signature.
The server's swanctl --log doesn't throw an error.
However, logcat on the Android device hangs at "android.net.ipsec.ike.exceptions.AuthenticationFailedException: Unrecognized ASN.1 objects for Signature algorithm and Hash" and "IkeAuthDigitalSignPayload: Unexpected or repeated Signature Hash Algorithm: 5" errors
I want to roll back to RSA just for compatibility at this point. I'm not sure any benefits of ECDSA is worth incompatibility with OS native tools.
