XIII
On my AC86U (with Asuswrt-Merlin) I use Let's Encrypt (wildcard) certificates for a personal domain to access my router. Today was the first time (since LE's R3 certificate expired in September) that I had to access the web interface from Safari on macOS, which failed. I had a similar issue with the Mosquitto MQTT broker on a Raspberry Pi, but (re)generating LE certificates using certbot (on a Raspberry Pi) with this option solved that:
However, using those new certificates did not help fix it for my router (I tried uploading these certificates via the web interface as well as manually putting them in /jffs/.cert/ and restarting the httpd server).
How can I fix this for my router as well?
--preferred-chain "ISRG Root X1"
