royarcher
I have been having problems with my download going from 50+ to 9 MBS.
Every time it happened I would go through the motions,eg reset the modem and router and in extreme cases factory reset the router ( rt AC 88 U ) and eventually it will go back to 50+ MBS.
Yesterday however nothing worked so I unplugged and plugged the Ethernet cable back in(10 metres) from the modem and it worked for a while so I unplugged and plugged it back into the router and it worked and continued to work when I checked this morning before going to work 4 .30 am.
My question WTF is going on here?? the cable music be about 3 years old now but I am not sure if it's a dicky port on the router or the cable.
I know that the ports are a bit wonky because just picking the router up can upset it . Is there a way to rule the cable either in or out?
