Hey All,
ASUS Merlin 388.2_2 on RT-AX88U
I’m trying to keep the RAM usage under control when I use transmission via entware. I have a 2GB SWAP file setup and I’ve configured transmission to use my 256GB pen drive attached. Downloads do complete successfully.
400MB (40%) free RAM before downloading a torrent. Once the torrent starts, it eats the RAM up until 97% utilised.
I’m assuming the torrent is being downloaded into RAM, then either using the SWAP file, or copying direct to the destination. This is a problem, as even when the torrent is done, the RAM is permanently full until I remove/trash the download. Assuming RAM at 97% will be having a negative impact to other services on the router, including WiFi
I’ve tried changing the “cache-size-mb”, “peer-global-limit” and “peer-limit-per-torrent” but no difference.
Have I got a configuration error here? Is there a way to download straight to storage/SWAP, or even just restrict how much RAM transmission can use?
Thanks in advance!
Thanks in advance!
