Hi everyone,
I'm about to buy a new router, but can't really figure out which one would be the best for me. I'm getting a 120Mbit connection and can unfortunately only connect wireless. I've got a recent Macbook Pro which has an N (dual band) receiver.
Having read quite some articles here, I'm pretty sure I won't be getting 120Mbit in any way (wireless). Obviously, I do want to get as high as possible performance. I'm about 5 meter from the router, with 2 walls between the router and me.
I was having doubts between the Linksys WRT610n and the Netgear WNDR3700. Are these indeed the best options, or is there another router that performs better/equally when connected wireless? If not, which of the two do you think would be the better choice for me?
I don't really care much about the price, as long as it stays under €150,-. I can get the two I mentioned for €129,- and €104,- respectively.
Thanks in advance!
Thanks in advance!
