List associated WiFi clients on command line?
Jack Yaz
Part of the Furniture
Like Wireless Log, but in a terminal. I can see the page is using AJAX but I can't follow it at that point, AJAX is a mystery to me!
It varies between router models.
Thanks, I can then use arp and other commands to get hostname and ip address!
Like in my wireless monitor script ;).
#!/bin/sh
# This script only works with Broadcom wireless chipsets, not Quantenna.
# https://www.snbforums.com/threads/to-trace-mobile-mac-adress.20022/#post-144852
oldlist=/tmp/assoclist.old
newlist=/tmp/assoclist.new
touch $oldlist          # Create an empty file the first time through
while sleep 15
do
        for iface in $(nvram get wl_ifnames) $(nvram get wl0_vifs) $(nvram get wl1_vifs)
        do
                wl -i $iface assoclist >> $newlist
                sed -i "s/assoclist/$iface/g" $newlist
        done
        grep -vxFf $newlist $oldlist | while read macinfo
        do
                macaddr="${macinfo#* }"
                arpinfo="$(arp -a | grep -iF $macaddr | awk '{print $1 " " $2}')"
                logger -t "wireless" $macinfo $arpinfo "has disconnected."
        done
        grep -vxFf $oldlist $newlist | while read macinfo
        do
                logger -t "wireless" $macinfo $arpinfo "has connected."
        done
        mv $newlist $oldlist
done
#!/bin/sh
while sleep 15
do
        do
        done
        do
                logger -t wireless $macinfo $arpinfo "has disconnected."
        done
        do
                logger -t wireless $macinfo $arpinfo "has connected."
        done
done
Would you mind if i incorporate it (while adding support for my ac87u) as a status output for YazFi? I'll be sure to credit you in the code!
By all means. It's all free code, I don't have copyright on awk, sed or grep :D. In fact I'd like to see a version that also worked with Quantenna. I would have written one myself but had no way of testing it.
Cheers. I still prefer being polite and asking! I'm hoping the linked post you sent with Merlin's input on the Quantenna input will be enough, otherwise at least i know where to start!
So for the primary networks, using
is wifi0 2.4ghz and eth1 5Ghz?
Or as per John's post in the linked thread,
eth1 2.4ghz
eth2 5ghz
and wifi0 is a red herring?
This is what I didn't know because I don't have an RT-AC87U.
All I know is that other post refers to wifi0 which is apparently the Quantenna 5GHz radio???
On the Broadcom based routers:
eth1 - 2.4GHz
eth2 - 5GHz
wl0.x - 2.4GHz guest
wl1.x - 5GHz guest
I don't know whether it's possible to identify whether a Quantenna client (wifi0) is on a guest network or not.
What do you get on your RT-AC87U for:
nvram get wl0_vifs
nvram get wl1_vifs
eth1 - 2.4GHz
eth2 - 5GHz
wl1.x - 5GHz guest
eth1 probably works on 87U but I have (unhelpfully, for this test) named both 2.4 and 5 with the same SSID.
wifi0 (via qcsocket) works for primary 5GHz, and wl0.x for 2.4GHZ also works
I'm also interested in this, I have an RT-AC87U running Merlin 380.70. Here's what I get, let me know if you need more
me@87u:/tmp/home/root# nvram get wl_ifnames
eth1 wifi0
me@87u:/tmp/home/root# nvram get wl0_vifs
wl0.1
me@87u:/tmp/home/root# nvram get wl1_vifs
wl1.1
Hi Colin, below is the router's output, this is with both radios on with one guest wifi on each, I have different ssid names per radio.
Note I have an isolated vlan100 that i use for some wired devices. Bridging a new vlan with the guest wlans is on my list of things to do, a while back I made an attempt but it didn't work as I don't keep the guest wlans on all the time and they would drop back onto br0 when reactivated.
me@87u:/tmp/home/root# ifconfig -a
aux0      Link encap:Ethernet  HWaddr 9C:::::
          BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:28844 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:2227820 (2.1 MiB)  TX bytes:0 (0.0 B)
          Interrupt:180 Base address:0x5000
br0       Link encap:Ethernet  HWaddr 9C:::::
          inet addr:10...  Bcast:10...  Mask:255.255.255.0
          UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
          RX packets:394589 errors:0 dropped:0 overruns:0 frame:0
          TX packets:504231 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:32081386 (30.5 MiB)  TX bytes:553110262 (527.4 MiB)
br0:0     Link encap:Ethernet  HWaddr 9C:::::
          inet addr:169.254.39.93  Bcast:169.254.39.255  Mask:255.255.255.0
eth0      Link encap:Ethernet  HWaddr 9C:::::
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:3695701 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1290999 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:627446434 (598.3 MiB)  TX bytes:660557364 (629.9 MiB)
          Interrupt:181 Base address:0x6000
eth1      Link encap:Ethernet  HWaddr 9C:::::
          RX packets:1907 errors:0 dropped:0 overruns:0 frame:21239
          TX packets:3272 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:221559 (216.3 KiB)  TX bytes:2250781 (2.1 MiB)
          Interrupt:163
ifb0      Link encap:Ethernet  HWaddr 26:::::
          BROADCAST NOARP  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          collisions:0 txqueuelen:32
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
ifb1      Link encap:Ethernet  HWaddr B6:::::
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING MULTICAST  MTU:16436  Metric:1
          RX packets:83802 errors:0 dropped:0 overruns:0 frame:0
          TX packets:83802 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:21630137 (20.6 MiB)  TX bytes:21630137 (20.6 MiB)
tun21     Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          inet addr:10...  P-t-P:10...  Mask:255.255.255.0
          UP POINTOPOINT RUNNING NOARP PROMISC MULTICAST  MTU:1500  Metric:1
vlan1     Link encap:Ethernet  HWaddr 9C:::::
          RX packets:293625 errors:0 dropped:0 overruns:0 frame:0
          TX packets:414362 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:22510933 (21.4 MiB)  TX bytes:427144393 (407.3 MiB)
vlan100   Link encap:Ethernet  HWaddr 9C:::::
          inet addr:192...  Bcast:192...  Mask:255.255.255.0
          TX packets:111 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:14578 (14.2 KiB)
vlan2     Link encap:Ethernet  HWaddr 9C:::::
          RX packets:3430623 errors:0 dropped:0 overruns:0 frame:0
          TX packets:881778 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:4882193175 (4.5 GiB)  TX bytes:230483829 (219.8 MiB)
vlan4000  Link encap:Ethernet  HWaddr 9C:::::
          RX packets:297 errors:0 dropped:0 overruns:0 frame:0
          TX packets:324 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:21186 (20.6 KiB)  TX bytes:27852 (27.1 KiB)
wl0.1     Link encap:Ethernet  HWaddr 9C:::::
          RX packets:135867 errors:0 dropped:0 overruns:0 frame:21239
          TX packets:151574 errors:108 dropped:0 overruns:0 carrier:0
          RX bytes:169820059 (161.9 MiB)  TX bytes:198295295 (189.1 MiB)
me@87u:/tmp/home/root# robocfg show
Switch: enabled
Port 0: 1000FD enabled stp: none vlan: 2 jumbo: off mac: ::::::
Port 1:   DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 2: 1000FD enabled stp: none vlan: 1 jumbo: off mac: ::::::
Port 3: 1000FD enabled stp: none vlan: 1 jumbo: off mac: ::::::
Port 4:   DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 5: 1000FD enabled stp: none vlan: 1 jumbo: off mac: ::::::
Port 7: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 9c:::::
Port 8: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 9c:::::
VLANs: BCM5301x enabled mac_check mac_hash
   1: vlan1: 1 2 3 5 8t
   2: vlan2: 0 8t
 100: vlan100: 1t 2t 3t 8t
1045: vlan1045: 7 8u
1046: vlan1046: 0 1t 2t 4 7t 8t
1047: vlan1047: 0 2t 4t 5t
1099: vlan1099: 1 2t 3t 5t 7
1100: vlan1100: 1 3t 4t 5 7t
1101: vlan1101: 1 3 4 7 8u
1102: vlan1102: 1t 2t 5t
1103: vlan1103: 0 1t 4t 5 7t 8u
4000: vlan4000: 5t 7t
me@87u:/tmp/home/root# brctl show
bridge name     bridge id               STP enabled     interfaces
br0             8000.9c:::::            no             vlan1
                                                        vlan4000
                                                        eth1
                                                        wl0.1
For reference here's the 87u's switch port to interface layout
port0 wan
port1 lan4
port2 lan3
port3 lan2
port5 lan1 (quantenna chipset)
Does your 5ghz guest wifi actually broadcast? Mine doesn't and that's having done a factory reset.
Edit : never mind i see you're on 380.70, mine stopped working after the jump to 384.x
Indeed and that's one of the reasons I'm holding on to the 380 code.
