Local domain queries are still forwarded to upstream DNS even though the setting is No
loveleeyoungae
I've accidentally found out that this setting seems to be ignored. I set:
Forward local domain queries to upstream DNS: No
But querying for local hosts/IPs in the router itself, it still forwards those queries to upstream DNS:
admin@RT-AC68U-9520:/tmp/home/root# nslookup dc
Server:    8.8.8.8
Address 1: 8.8.8.8 dns.google
nslookup: can't resolve 'dc'
admin@RT-AC68U-9520:/tmp/home/root# nslookup dc.home.lan
Server:    8.8.8.8
nslookup: can't resolve 'dc.home.lan'
admin@RT-AC68U-9520:/tmp/home/root# nslookup 192.168.7.11
Server:    8.8.8.8
Address 1: 192.168.7.11
admin@RT-AC68U-9520:/tmp/home/root# nslookup dc 192.168.7.1
Server:    192.168.7.1
Address 1: 192.168.7.1 RT-AC68U-9520.home.lan
Address 1: 192.168.7.11 DC.home.lan
May it be some bug in the firmware or is it more or less due to some conflict in the configurations?
My current setup (screenshots below):
192.168.7.110: a Pi running Adguard Home + unbound acts as DNS server, all AGH private+reverse DNS settings are enabled and set to forward to router
192.168.7.1: the AC68U router acts as normal router except being DNS server:
+ LAN DHCP page: only Pi's IP is set as DNS Server 1; doesn't advertise router's IP
+ WAN: No to all "WAN DNS Setting"
+ DNS Filtering is disabled (just let those DNS hard-coded devices go as they want)
That setting only applies to LAN clients, not the router itself. For the router set Tools - Other Settings > Wan: Use local caching DNS server as system resolver = Yes.
Didn’t someone say “Use local caching DNS server as system resolver = Yes” is being removed in codebase 3006? I have a faint recollection of that.
My bookmark memory doesn’t recall the content of the conversation or who.. so I could be misremembering something else.
Yes. RMerlin said that. But that wouldn't apply to the OP's RT-AC68U.
Fair point. Was just a stray thought that was triggered in my mind. Thanks for reaffirming.
Thank you! Didn't know about that little but important difference in settings for clients vs router. Though changing the setting you mentioned didn't help with diagnosing my DNS loop issue, it cleared my doubt :)
