Local name resolution on RT-AC68R
lzkill
Hi folks.
I've set several static IPs on my RT-AC68R, but somehow they won't get resolved from my client machines. The resolution works fine from the router itself... I read in another post that OpenDNS messes with the local resolution, which in case I'm using. Does is it still apply?
Thanks in advance!
Using Parental control > DNS-based filtering will bypass local name resolution. Also, setting a value in LAN > DHCP Server > DNS Server will make clients bypass the local DNS server.
