Log Format issues
abl75
Hello
After installing 378.55 and using it for quite a while, I started having trouble with my connection.
When I saved the router log to send it to support and opened iut, the format does not contain carriage returns as it did on previous versions, and the result is quite illegible.
Any idea of why is that happening ?
I am attaching an old (routerlog0721) log from version 378.53 and a new log file (routerlog0818)
Have you changed/updated browsers recently? The handling of textbox output can be browser specific.
The first log has windows line endings, the second unix. Notepad++ can open both and convert if necessary. windows wordpad probably opens both but notepad doesn't understand unix format.
