Rocketboy235
Hello,
Recently, I was able to update my router (after doing a complete factory reset and erasing NVRAM for good measure) to v386.1_2 on my AC68U as well as my 2 AiMesh nodes (also AC68U) and I realized that sometimes, my remote log server would see all of this spam happen. Never experienced this issue beforehand in my few years of using the routers.
I replaced the actual Mac Address of the AiMesh node below to 00:00:00:00:00:00 FYI
I would think this kind of message in the logs is harmless but I just saw that it repeated this message 100x all around Apr 10 06:50:25. I'm not exactly sure what is going on here.
Below is my log usage for the main router. The higher the blue bar on each day, the more logs it received that day and it mostly all points to the following logs above.
I do see that someone also experienced a similar issue and mentioned it here though they seemed more concern about the logging functionality than the actual log message spam:
Apr 10 06:50:25 RT-AC68U-Main-Router syslog wlceventd_proc_event(490): eth2: Deauth_ind 00:00:00:00:00:00, status: 0, reason: Class 2 frame received from nonauthenticated station (6), rssi:0
Probably bug in 386.1_2 - Remote Log
Hi, after upgrade to 386.1_2 my RT-AC68U is sending to remote syslog server all logs, and it does not matter, what settings I choose. All with Notice and above level are sent, event with bellow settings: Any idea how to limit that? I can't use that now, as my NAS disks will be killed very...
www.snbforums.com
