stray_coder
Where are entries created using the logger cli tool captured? They don't appear to be going to syslog.
They are sent to syslog. Check that the priority level you're using isn't below that set for "Log only messages more urgent than" on the System Log page.Where are entries created using the logger cli tool captured? They don't appear to be going to syslog.
Thanks @ColinTaylor.There are sent to syslog. Check that the priority level you're using isn't below that set for "Log only messages more urgent than" on the System Log page.
Do you have the Asuswrt-Merlin F/W currently installed on your router?I actually don't have that option in either System Log / General Log nor the Administration / System configuration pages. Are you sure the setting is still exposed in the UI.
Thanks, @Martinski.Do you have the Asuswrt-Merlin F/W currently installed on your router?
If so, what is the release version?
Perhaps you're running the stock AsusWRT F/W, in which case you may not have the GUI option in the "System Log --> General Log" webpage to set the message log level.
And yes, the "Log only messages more urgent than" setting is still available in the latest Asuswrt-Merlin 386.5_2 version.
I'd highly recommend you double check first and then, at the very minimum, provide exactly your router model & the F/W version you have running. That info will provide more context to your specific situation.
Can you provide a screenshot of the "System Log --> General Log" webpage to see what you do have on the GUI?Thanks, @Martinski.
Firmware Version:386.5_2
Router model: RT-AX58U
Had another check and definitely not seeing the option.
As an example, here is a screenshot from my router:Had another check and definitely not seeing the option.
Here you go.Can you provide a screenshot of the "System Log --> General Log" webpage to see what you do have on the GUI?
Ah, you have the Scribe + uiScribe add-ons installed. That changes things significantly. As usual, context is important.Here you go.
Maybe it's a hardware limitation?
So to answer your question, unless another filter is at work, they end up in /opt/var/log/messages.Where are entries created using the logger cli tool captured? They don't appear to be going to syslog.
Thread tagged but unsure how to relocate. Any thoughts?So to answer your question, unless another filter is at work, they end up in /opt/var/log/messages.
You might tag this thread with "scribe" and move it to the add-ons section, keep it tidy.
Welcome To SNBForums
