WhoYaGonnaCall
Hi All,
I recently tried logging into my router only to find I couldn't because someone was already logged in. I don't recall logging in myself, so I've gone down the path of resetting the router, changing passwords etc. I suspect I might have turned on WAN access at some point without thinking, which isn't a good idea but nonetheless, should be corrected now. So on to the question (apologies if this has been asked, I did try to search):
I'd like to confirm when someone logs in or attempts to log in to the router, but can't see this in the log in the UI. It seems only SSH access is logged (dropbear[26602]: Password auth succeeded...)
Is it possible to see logins (successful, failed) to the Web UI interface anywhere? (currently at version 386.1_2)
Thanks in advance
Thanks in advance
