P
Pir8pete
Guest
In the beginning I owned a RT-N66U "Dark Knight" Router and the Logitech Alert 750C Surveillance system they worked 100% together out of the box.
Over the past few years I've upgraded to the RT-AC66U then the RT-AC1900P and then tried the new RT-AC86U using the latest firmware Version 3.0.0.4.382.16466 available with no luck.
What I've noticed is that "ever since" switching from the N66, compatibility has been getting worse between these two devices. I find this odd as a plugged in ethernet device with no settings to configure.
Now I really wanted to upgrade the main household router to the new RT-AC86U for it's faster Wi-Fi and USB port for a connected HDD but as I explain below I'm not able to unless I scrap the Logitech Alert 750C Surveillance system. :/
NOTES:
-Logitech Alert 750C Surveillance system worked flawlessly with the N66.
-With the RT-AC66 the Logitech system wouldn't show up as connected if the router was rebooted, odd but OK.
-Same with RT-AC1900P, I need to power cycle the Logitech system after the router was already powered on and booted up.
Now with Asus newest router RT-AC86U it doesn't matter what I do it will not show up as a connected device, so I had to reinstall the RT-AC1900P till I figure this out.
I have decided to make this thread and see if anyone has found a solution?, I can't be the only one pairing these devices together!
I'm also going to contact Asus support router_feedback@asus.com and see what they have to say but I'm sure I'll just get a canned response if any. I'm not scrapping a perfectly good surveillance system that costed over $400
Below is my setup; the AC1900P / Logitech Alert 750C Surveillance system.
NOTES:
