I have seen this a few times where logs are no longer getting updated. After reboot everything is fine. For example here are entries from messages when i rebooted
Similarly openvpn log. I was restarting vpn client and notcing the log was not getting updated and then rebooted the device 12/22 8:19 and the log started getting updates.
I confirmed i have space left on the device
Running:
RT-AC88U: 386.3.2
YazFi v4.3.4
scribe v2.4.3
uiScribe v1.4.5
Anyone seen this and have pointers on what could be going on?
Dec 19 00:00:58 RT-AC88U-BC40 dnsmasq-dhcp[28068]: DHCPACK(wl0.2) 192.168.3.207 90:03:b7:f6:53:3d
Dec 22 08:19:14 RT-AC88U-BC40 uiScribe: Mounting WebUI page for uiScribe
Dec 22 08:19:14 RT-AC88U-BC40 uiScribe: Mounted uiScribe WebUI page as Main_LogStatus_Content.asp
Dec 18 23:51:16 RT-AC88U-BC40 ovpn-client1[27976]: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Dec 18 23:51:16 RT-AC88U-BC40 ovpn-client1[27976]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA256
Dec 22 08:19:22 RT-AC88U-BC40 openvpn-routing: Routing mbp from 192.168.1.219 to any through ovpnc1
Filesystem Size Used Available Use% Mounted on
/dev/root 32.3M 32.3M 0 100% /
devtmpfs 251.4M 0 251.4M 0% /dev
tmpfs 251.6M 1.1M 250.5M 0% /tmp
/dev/mtdblock4 64.0M 3.5M 60.5M 6% /jffs
/dev/sda1 14.8G 206.7M 13.8G 1% /tmp/mnt/merlin
tmpfs 251.6M 1.1M 250.5M 0% /www/require/modules/menuTree.js
/dev/mtdblock4 64.0M 3.5M 60.5M 6% /www/Main_LogStatus_Content.asp
arpit@RT-AC88U-BC40:/tmp/home/root#
Running:
RT-AC88U: 386.3.2
YazFi v4.3.4
scribe v2.4.3
uiScribe v1.4.5
