Looking for a 802.11n router recommendation (edited)
Since my Edimax BR-6114Wg is dying, I've decided to buy a new router. I've had a lot of range & speed issues with my laptop (which support 802.11n), so I decided to buy a draft-N router.
My budget is around 100$.
I must say that I was really unsatisfied with the 6114Wg - the web UI was *very* slow, the router stopped responding once in a while, and the range really sucked.
It's very important to me that: a. the range will be as large as possible, b. the UI won't suck like the Edimax one.
I'm going to buy it from newegg.com.
The routers which fit my budget are:
Buffalo WZR-HP-G300NH (108$)
ASUS RT-N16 (108$)
Linksys WRT320N (102$)
D-Link DIR-655 (100$)
Belkin F5D8235-4 (80$)
Linksys WRT160N (75$)
Which one do you recommend?
Thanks in advance!
ASUS RT-N16 (108$)
Thanks in advance!
