Looking for fast OpenVPN hardware
Justin How
Sorry if I am repeating a much asked question.
I have a Asus RT-N66U running Merlin which manages about 1.6Mbytes/se OpenVPN (AES 128bit).
I am hoping that something could provide around 5Mbyte/sec. without spending a fortune.
Is there such a thing - do Asus do a router that would be this fast? Wireless would not be used so is unimportant.
Thanks in advance.
Justin
Thanks in advance.
Justin
Using the RT-AC1900P myself, I can confirm that it reaches 6.5mbps over OpenVPN on my 7.5mbps connection (using AES-128-CBC).
As Odkrys stated above, this router should easily be able to handle 40mbps download (depending on your connection).
Which speed is your bare internet connection?
Thanks in advance.
Justin
That's odd...I have a N66U that I just set up OpenVPN on and I did a speed test over the VPN connection and achieved the following results: 5.48 down / 6.56 up...unless I am missing something here? Same perimeters as well with encryption.....
Thanks for the info
Is the RT-AC3200 appreciable faster (OpenVPN wise) than the RT-AC1900? Currently I can get it at quite a good price
Thanks for the info
The RT-AC3200 is not faster.
RT-AC1900P has a Broadcom (BCM4709C0) 1.4Ghz dual core processor.
RT-AC3200 has Broadcom (BCM4709A0) 1Ghz dual core processor.
Thanks in advance.
Justin
If you want a fast and easy to use VPN connection look at the hardware solutions and customized Tomato firmware from Sabai Technology. I get the following speeds when connected to an Astrill VPN server in Chicago while my physical location is in SW Florida.
http://www.speedtest.net/my-result/5837771993
Those are very decent speeds for on-router VPN (if you are using AES128bit encryption or higher), but an Asus RT-AC56U at $239.99 is "a bit ;)" overpriced when the same standard router is $86 on Amazon (straight from Asus).
Beside that, I don't see any advantage in their (to me misleading) description of their "modded" Asus routers. They sell their RT-AC68U for $359.99 and ancient RT-N66U for $219.99 :eek:
OpenVPN clients run very well on my RT-AC1900P with AsusWRT-Merlin firmware and are easy to set-up.
How could they sell product with a fork of Tomato without leaving it GPL available ?
I personally doubt it could be faster than official firmware as some driver are closed source.
