digital_alchemy
I'm trying to plan my first NAS build. I think I have a fairly good plan on what component to use; but would appreciate a dummy check from some more experienced builders.
Components:
Case: IstarUSA D-406-B6SA
Motherboard: ASUS P5Q Pro
CPU: Intel Core 2 Duo E7400
Raid Controller: 3ware 9650SE-8LPML
Drives: WD Black WD1001FALS
Memory: OCZ Fatal1ty Edition 2GB
Of course I want the best performance possible within a reasonable budget... not sure yet what to expect from this setup but I think it should be ok.
I initially was just going to build a NAS system, but the more I thought about it I decided I wanted to incorporate a raid for backup purposes also. The way I would like to set this up is: 4 1TB drives for NAS in Raid 5 and then have 3 Drives dedicated as a raid 5 backup to store all system and NAS weekly backups.
My major question would be: is this possible with a single raid controller since it can handle 8 drives or would I need separate controllers for the NAS and the Backup array?
I've still not settled on an OS yet either. I'm probably looking at FreeBSD or Ubuntu. I only have limited experience with using FreeBSD as a desktop OS, but I think I should be able to figure out how to use them as a NAS OS
Thanks for all advice/help.
Components:
