Wafflestyx
I currently have a RT-AX86U (with merlin) located in my basement and would like add something on the second floor of the house. (would be running ethernet to connect them)
Is there any benefits or disadvantages to using a extender like the ASUS RP-AX58 over another AX router? Less range?
I'm guessing the RP is just plug and play where the router I would need to set up first and give me extra Ethernet ports (if anyone in the room where it would to use)
If a router would be the better option does it really matter what the specs are?
The rt-ax55 can be had for about 30-40 on eBay, if this is a bad choice to pair please suggest something else.
Thank you.
Thank you.
