TP-LINK has emulators online so you can try out the Web Admin UI.
I've worked on Cisco on VLAN Projects I was in charge for 5,000 switch project and Network Refresh Project of 20,000 Cisco Catalyst Switch replacements 24 and 48 port Gigabit switches. Update firmware and deployment into network closets around the campus.
So you can't go wrong with a Cisco Switch. Cisco Linksys Switches I have about two of those. I did try out Netgear Prosafe Web Smart Switch. Didn't care for the Web Admin UI and then the switch started to give me issues.
TP-LINK JetStream Managed L2 switch has served my purpose here. Has 5 year warranty for the SMB Enterprise Network Gear they peddle. I just did a firmware upgrade on it.
Tipster,
I think you make a good point in making sure product differentation is considered.
I WAS trying the Netgear Web Smart Switch, and yes, I think that was my problem. It is a new product, to be fair, and might be having some growing pains as most new products do.
I also had a TP-Link switch, that while it was a solid switch, it had a very small, loud fan inside of it, that I can only imagine will fail at some point. Indeed, many user reviews online state that this fan does fail frequently, and opening the switch to replace it voided the warranty.
Finally, I did try out a new D-Link smart switch, which I thought for the price would have been awesome. I've previously had nothing but problems with D-Link (their DIR-855 debacle), but decided for the price (3x less than a comparative Cisco product that I eventually bought) I had to give it a go. Major mistake. The firmware wouldn't even save the settings I applied. Not really sure how that even makes it past QC to be released. But I digress.
Anyway, like I said, I had had enough with the variability for a managed switch, so I spent the money I should have in the beginning and purchased the Cisco. Did I pay too much for it? Yes. Does it work just the way it should without having to fudge things and learn ambiguous or sometimes confusing terms? Yes. Is that worth the premium? To me it was. To some others, maybe not. But in the end I have a managed 26-port gigabit switch that will have the same terms and interfaces across all lines (I have two 8-port managed gigabit switches in the same line), and, more importantly, I have the power of Google to do basically anything I choose to do with those switches.
I'm not always a fan of big name brands, but there are times when there's a reason that these big name brands are still in business. In this case, I think there is a reason that higher-end networking equipment is dominated by Cisco.
