MAC Address Filter Per SSID?
CntrlAltDel
Hi there,
I have an ASUS RT-AC88U running in AP mode with Merlin 386.14_2 f/w.
Does anyone know of a way to get wireless MAC address filtering (whitelisting) enabled but only for specific SSID's?
I want to have a LAN isolated SSID that I can use for 'quick-connect' without a password.
My use case is that I have a group of devices that I constantly wipe and dont want to have to deal with having to reconnect to my Wi-Fi SSID with a password.
You can't have main LAN isolated SSID in AP Mode to begin with.
Hi there,
Double NAT a second router in front of your first router for these devices to connect to. Use a very secure admin password for this router and restrict admin access to a certain IP. Set up the WiFi connection type to be open. Then depending on what security features are available do what you can to restrict access to only certain devices by assigning them static IPs. Depending on the open router's firmware you can see if it will work if you disable assigning IPs and instead all devices use static IPs. If turning off DHCP assignments causes problems set the IP pool to be just one IP address and plug an Ethernet wired device into a lan port on the first router so it will be assigned the single address in the IP pool. Your WiFi clients will be assigned a static IP outside the pool.
This double NAT solution has low practicality. First, the AP is lost at current location where it’s probably needed; second, everything relying on UPnP on the double NATed router will stop working properly; third, port forwarding must be set for eventual open to Internet services. Asus services like Instant Guard won’t work either. May turn into more damage done than possible solution. The new requirements just exceed the old equipment capabilities. Wrong equipment for the task.
If
If OP needs/wants to run a server on the second router then it certainly becomes more complicated requiring double port forwards. As for the UPnP issue I have never had a problem when running in double NAT. As for location of AP nothing says OP couldn't still use the AC88 as an AP while using another older router as the Internet facing router as long as it had GB LAN ports and a reasonable processor.
You never had an issue because you never needed UPnP. It doesn't work in double NAT. Your solution requires more devices and perhaps located in wrong places. As per older posts the OP has OPNsense router. What is needed - proper AP with native VLAN support. AX1800 class APs start under $100. Other option is scripting VLANs in Asuswrt-Merlin, if the OP is comfortable doing it after some research.
