mac address parental control
BigDLondon
Is there a mac address Parental Control firmware update via web gui ? I'm using default 1.0.1.7 f Thanks BigD
Thanks for the fast reply . How hard is it update and does it have parental control web gui ?Do you have a screen shot? Thanks BigD
I've installed 3.0.0.4_206 to get parental controls but after entering name and mac address than pressing apply all I get is
Parental control allows you to set the time limit for a client's network usage. To use parental control:
In the [Clients Name] column, select the client whose network usage you want to control. You may also key in the clients MAC address in the [Clients MAC Address] column.
In the [Add / Delete] column, click the Edit icon.
Set up allowed time limits in the [Time Management] map. Drag and drop to desired day/time.
Click [OK] to save the settings made.
Click to open tutorial video.
No full setup Thanks BigD
Parental Control Bug RT-N66U 4.246 firmware
I also have this issue. Once I set a rule under the parental control, all I get on my GUI, no matter which browser, is the instructions without the interface on the bottom of the page to see my settings, or change them.
I tried re-flashing a fresh copy of the 3.0.0.4.246 firmware from ASUS, but no help.
Does Merlin's newest build solve this?
Jeremy told me not to use Special characters ie " Bob's laptop " instead use " bobs laptop ".It's a bug they haven't fixed yet.
