Major major issue with AC66R since move
Find the Door
Just moved and am having MAJOR issues with my AC66R... was recently running .979 then just switched to Merlin's .34 build in desperation only to be faced with the same issues.
On boot everything seems "fine" then for whatever reason if I disable IPV6 (need to for Xbox 360 otherwise stuck at Strict NAT) I'm locked out of router settings hardwired.
So then I proceed to switch over to WiFi to configure the rest of my settings. The routers been acting VERY strange since I've moved. I'm not sure as to why, but it is running hotter (to the touch) and the 2.4 ghz band just flat out drops at times.
Here's my log:
http://www.twitlonger.com/show/n_1rqr3mb
Please help - I'm desperate!
