Nov 28 10:09:41 kernel: usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
Nov 28 10:09:41 kernel: scsi host0: uas
Nov 28 10:09:41 kernel: scsi 0:0:0:0: Direct-Access CT240BX5 00SSD1 0 PQ: 0 ANSI: 6
Nov 28 10:09:41 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Nov 28 10:09:41 kernel: sd 0:0:0:0: [sda] 468862128 512-byte logical blocks: (240 GB/224 GiB)
Nov 28 10:09:41 kernel: sd 0:0:0:0: [sda] Write Protect is off
Nov 28 10:09:41 kernel: sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
Nov 28 10:09:41 kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Nov 28 10:09:41 kernel: sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
Nov 28 10:09:41 kernel: sda: sda1
Nov 28 10:09:41 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Nov 28 10:09:49 custom_script: Running /jffs/scripts/pre-mount (args: /dev/sda1 ext4)
Nov 28 10:09:49 amtm disk check: Probing 'ext4' on device /dev/sda1
Nov 28 10:09:49 amtm disk check: Running disk check with command 'e2fsck -pfv' on /dev/sda1
Nov 28 10:09:54 amtm disk check: Disk check done on /dev/sda1
Nov 28 10:09:54 hotplug: USB ext4 fs at /dev/sda1 mounted on /tmp/mnt/SSD-REDACTED
Nov 28 10:09:54 usb: USB ext4 fs at /dev/sda1 mounted on /tmp/mnt/SSD-REDACTED.
Nov 28 10:09:54 kernel: EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: user_xattr
Nov 28 10:09:54 custom_script: Running /jffs/scripts/post-mount (args: /tmp/mnt/SSD-REDACTED)
Nov 28 10:09:54 Entware: Starting Entware and Diversion services on /tmp/mnt/SSD-REDACTED
Nov 28 10:09:54 uiDivStats: taildns not started: dnsmasq logging is disabled
Nov 28 10:09:54 rc_service: service 7685:notify_rc restart_dnsmasq
Nov 28 10:09:54 custom_script: Running /jffs/scripts/service-event (args: restart dnsmasq)
Nov 28 10:09:54 rc_service: hotplug 7602:notify_rc restart_nasapps
Nov 28 10:09:54 rc_service: waitting "restart_dnsmasq" via ...
Nov 28 10:09:54 dnsmasq[6787]: exiting on receipt of SIGTERM
Nov 28 10:09:54 uiDivStats: /tmp/mnt/SSD-REDACTED contains Entware, starting uiDivStats
Nov 28 10:09:54 custom_config: Appending content of /jffs/configs/dnsmasq.conf.add.
Nov 28 10:09:54 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf)
Nov 28 10:09:54 uiDivStats: Stale lock file found (>600 seconds old) - purging lock
Nov 28 10:09:55 Diversion: Mounting Diversion WebUI page
Nov 28 10:09:55 Diversion: Mounted Diversion WebUI as user1.asp in LAN/Diversion
Nov 28 10:09:55 Diversion: restarted Dnsmasq to apply settings
Nov 28 10:09:55 custom_script: Running /jffs/scripts/service-event (args: restart nasapps)
Nov 28 10:09:55 avahi-daemon[2304]: Files changed, reloading.
Nov 28 10:09:55 avahi-daemon[2304]: Loading service file /tmp/avahi/services/mt-daap.service.
Nov 28 10:09:55 iTunes: daemon is stopped
Nov 28 10:09:55 FTP_Server: daemon is stopped
Nov 28 10:09:55 Samba_Server: smb daemon is stopped
Nov 28 10:09:55 avahi-daemon[2304]: Got SIGTERM, quitting.
Nov 28 10:09:55 avahi-daemon[2304]: Leaving mDNS multicast group on interface br0.IPv4 with address 192.168.1.1.
Nov 28 10:09:55 avahi-daemon[2304]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.1.1.
Nov 28 10:09:55 avahi-daemon[2304]: avahi-daemon 0.8 exiting.
Nov 28 10:09:57 Timemachine: daemon is stopped
Nov 28 10:09:57 miniupnpd[6776]: shutting down MiniUPnPd
Nov 28 10:09:57 avahi-daemon[8405]: Found user 'nobody' (UID 65534) and group 'nobody' (GID 65534).
Nov 28 10:09:57 avahi-daemon[8405]: Successfully dropped root privileges.
Nov 28 10:09:57 avahi-daemon[8405]: avahi-daemon 0.8 starting up.
Nov 28 10:09:57 avahi-daemon[8405]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Nov 28 10:09:57 avahi-daemon[8405]: Loading service file /tmp/avahi/services/alexa.service.
Nov 28 10:09:57 avahi-daemon[8405]: Loading new alias name REDACTED.
Nov 28 10:09:57 avahi-daemon[8405]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.1.1.
Nov 28 10:09:57 avahi-daemon[8405]: New relevant interface br0.IPv4 for mDNS.
Nov 28 10:09:57 avahi-daemon[8405]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.1.1.
Nov 28 10:09:57 avahi-daemon[8405]: New relevant interface lo.IPv4 for mDNS.
Nov 28 10:09:57 avahi-daemon[8405]: Network interface enumeration completed.
Nov 28 10:09:57 avahi-daemon[8405]: Registering new address record for 192.168.1.1 on br0.IPv4.
Nov 28 10:09:57 avahi-daemon[8405]: Registering new address record for 127.0.1.1 on lo.IPv4.
Nov 28 10:09:57 avahi-daemon[8405]: Registering new address record for 127.0.0.1 on lo.IPv4.
Nov 28 10:09:58 Samba_Server: daemon is started
Nov 28 10:09:58 miniupnpd[8414]: HTTP listening on port 35073
Nov 28 10:09:58 miniupnpd[8414]: Listening for NAT-PMP/PCP traffic on port 5351
Nov 28 10:09:58 wsdd2[8415]: starting.
Nov 28 10:09:58 avahi-daemon[8405]: Server startup complete. Host name is REDACTED.local. Local service cookie is 3592888362.
Nov 28 10:09:58 avahi-daemon[8405]: Alias name "REDACTED" successfully established.
Nov 28 10:09:59 avahi-daemon[8405]: Service "REDACTED" (/tmp/avahi/services/alexa.service) successfully established.
Nov 28 10:10:14 uiDivStats: Mounting WebUI tab for uiDivStats
Nov 28 10:10:15 uiDivStats: Mounted uiDivStats WebUI page as user2.asp
Nov 28 10:12:56 dropbear[9089]: Child connection from 192.168.1.11:63114
Nov 28 10:12:57 dropbear[9089]: Password auth succeeded for 'REDACTED' from 192.168.1.11:63114
Nov 28 10:13:47 dropbear[9235]: Child connection from 192.168.1.11:63168
Nov 28 10:13:47 dropbear[9235]: Password auth succeeded for 'REDACTED' from 192.168.1.11:63168
Nov 28 10:14:47 dropbear[9235]: Exit (REDACTED) from <192.168.1.11:63168>: Error reading: Connection reset by peer
Nov 28 10:17:11 dropbear[9824]: Child connection from 192.168.1.11:63395
Nov 28 10:17:20 dropbear[9824]: Password auth succeeded for 'REDACTED' from 192.168.1.11:63395
Nov 28 10:18:26 acsd: eth6: COEX: downgraded chanspec 0x1806 to 0x1004: channel 11 used by exiting BSSs
Nov 28 10:24:56 dropbear[14865]: Child connection from 192.168.1.11:63945
Nov 28 10:24:56 dropbear[14865]: Password auth succeeded for 'REDACTED' from 192.168.1.11:63945
Nov 28 10:25:57 dropbear[14865]: Exit (REDACTED) from <192.168.1.11:63945>: Error reading: Connection reset by peer
Nov 28 10:33:30 acsd: eth6: COEX: downgraded chanspec 0x1806 to 0x1004: channel 11 used by exiting BSSs
Nov 28 10:48:34 acsd: eth6: COEX: downgraded chanspec 0x1806 to 0x1004: channel 11 used by exiting BSSs
Nov 28 11:00:00 uiDivStats: Starting stat update
Nov 28 11:00:01 uiDivStats: Stats updated successfully
Nov 28 11:02:29 rc_service: httpd 2329:notify_rc start_lltdc
Nov 28 11:02:29 custom_script: Running /jffs/scripts/service-event (args: start lltdc)
Nov 28 11:03:38 acsd: acs_set_chspec: 0x1806 (4l) for reason ACS_CSTIMER
Nov 28 11:03:38 acsd: eth6: selected_chspec is 1806 (4l)
Nov 28 11:03:38 acsd: eth6: Adjusted channel spec: 0x1806 (4l)
Nov 28 11:03:38 acsd: eth6: selected channel spec: 0x1806 (4l)
Nov 28 11:03:38 acsd: eth6: txop channel select: Performing CSA on chspec 0x1806
Nov 28 11:03:39 hostapd: eth6: IEEE 802.11 driver had channel switch: freq=2427, ht=1, vht_ch=0x0, he_ch=0x0, offset=1, width=2 (40 MHz), cf1=2437, cf2=0
Nov 28 11:04:04 rc_service: cfg_server 2403:notify_rc update_nbr
Nov 28 11:04:04 custom_script: Running /jffs/scripts/service-event (args: update_nbr)
Nov 28 11:33:49 acsd: eth6: COEX: downgraded chanspec 0x1806 to 0x1004: channel 11 used by exiting BSSs
Nov 28 11:33:49 acsd: acs_set_chspec: 0x1004 (4) for reason ACS_CSTIMER
Nov 28 11:33:49 acsd: eth6: selected_chspec is 1004 (4)
Nov 28 11:33:49 acsd: eth6: Adjusted channel spec: 0x1004 (4)
Nov 28 11:33:49 acsd: eth6: selected channel spec: 0x1004 (4)
Nov 28 11:33:49 acsd: eth6: txop channel select: Performing CSA on chspec 0x1004
Nov 28 11:33:50 hostapd: eth6: IEEE 802.11 driver had channel switch: freq=2427, ht=1, vht_ch=0x0, he_ch=0x0, offset=0, width=1 (20 MHz), cf1=2427, cf2=0
Nov 28 11:34:12 rc_service: cfg_server 2403:notify_rc update_nbr
Nov 28 11:34:12 custom_script: Running /jffs/scripts/service-event (args: update_nbr)
Nov 28 11:48:55 acsd: acs_set_chspec: 0x1806 (4l) for reason ACS_CSTIMER
Nov 28 11:48:56 hostapd: eth6: IEEE 802.11 driver had channel switch: freq=2427, ht=1, vht_ch=0x0, he_ch=0x0, offset=1, width=2 (40 MHz), cf1=2437, cf2=0
Nov 28 11:49:17 rc_service: cfg_server 2403:notify_rc update_nbr
Nov 28 11:49:17 custom_script: Running /jffs/scripts/service-event (args: update_nbr)
Nov 28 12:00:00 uiDivStats: Starting stat update
Nov 28 12:00:02 uiDivStats: Stats updated successfully
Nov 28 12:45:00 amtm routerdate: Preserving router date via cron (2024-11-28 11:45:00) UTC time.
Nov 28 13:00:00 uiDivStats: Starting stat update
Nov 28 13:00:02 uiDivStats: Stats updated successfully
Nov 28 14:00:00 uiDivStats: Starting stat update
Nov 28 14:00:01 uiDivStats: Stats updated successfully
Nov 28 15:00:00 uiDivStats: Starting stat update
Nov 28 15:00:02 uiDivStats: Stats updated successfully
Nov 28 16:00:00 uiDivStats: Starting stat update
Nov 28 16:00:02 uiDivStats: Stats updated successfully
Nov 28 17:00:00 uiDivStats: Starting stat update
Nov 28 17:00:01 uiDivStats: Stats updated successfully
Nov 28 17:20:01 Diversion: updated ads counter: 5,866,944 total, 3,368,895 this week, 37,177 new since last count
Nov 28 18:00:00 uiDivStats: Starting stat update
Nov 28 18:00:01 uiDivStats: Stats updated successfully
Nov 28 18:45:00 amtm routerdate: Preserving router date via cron (2024-11-28 17:45:00) UTC time.
