Manually Assigned IP Address Menu Ordering
TonyK132
When you 1st enter that menu, the list is ordered from highest value IP address to the lowest, but if you make a change, then the displayed list is ordered from lowest to highest. If you make another change, it goes back to highest to lowest. It appears to continue to toggle continuously. Is that display sequence intentional?
Thanks, fixed.
