connorm
well this all started because DHCP on the router failed to do its job properly, i have my xbox as 192.168.1.101 and my pc pat 192.168.1.100, randomly router would give pc 192.168.1.101, it is retarded but i told merlin and he didnt seem to have anything to say about it, my fix to this was manually entering static ip to xbox so it would not alow the router to give it another ip other then what i have assigned (since it keeps trying to), that fixed my dhcp issue i was having, but created another, when i manually entered network settings on xbox it seemed to not work with upnp anymore, nat was strict for no reason, manually forward port 3074, worked fine, then my brother xbox 192.168.1.102 also had open nat through upnp just like he used to (it set up a port forwarding rule for 19059), then next day, even tho i had 3074 manually forwarded (rule was still applied) the router just magically decided to forward 3074 for my brothers xbox aswell and then not give it back to me even tho in the port forwarding tab it showed it being forwarded to both consoles (mine first), so i turn upnp off and connected him to another router with dif ip, (i have 2 dynamic ip's and a switch), but now he moved across the house and the asus 5g network is the best to use for clear signal for gaming, i manually forwarded him 19059 and left upnp off due to previous issues, and it changed nothing, he has moderate nat with or without the forwarded port, if someone can explain why he gets open nat when 19059 is forwarded via upnp but not when via port forwarding, i would love to know why the frack the router acts like this, im thinking of just getting a new d link this is driving me crazy
