Mastiff: Init every 30 seconds?
Ola Malmstrom
I changed the "Log only messages more urgent than" from Notice to Warning a few days ago. This looked fine for a while. However after an automatic restart tonight around 03:30, I have started to get the message "Mastiff: init" about every 30 seconds or so.
When I browse the log file, I can see this message for a while after the previous restart. Then it disappeared by itself.
I have both QoS and AiProtection set to off after a complete factory reset about 2 weeks ago. Running 388.5 on a ZenWifi XT12 Pro.
Is this a real problem that I need to deal with or can I just ignore it? Everything seems to work fine, very low CPU load and nothing else that I can see.
Thanks MDM - tried search but probably not in all threads..... mea culpa!!
So my conclusions are:
  • it is a known issue and can be ignored since it doesn't do any harm
  • if I want to get rid of the message, I can set the "Disable Asusnat tunnel" to Yes which MAY affect performance
Nothing to do with performance (How did you get That??! 😅), just with some ASUS services (like ASUS App etc.).
I browsed through both links you sent. Lots of stuff..... I may have misunderstood something, but it was written that performance MAY be reduced with 20 % in some cases. Is that what you mean?
No, it is as I wrote - it does NOT affect performance, rather it can not! 😉
