psychopomp1
Hi
I noticed that i can't get more than ~15 mb/s in in download speeds when connected to my VPN provider via OpenVPN client in the RT-AC87R despite have regular speeds of 80/20 mbps. According to the VPN provider no router is capable of giving more than 10-20 mb/s OpenVPN speeds due to hardware limitations. Is this correct? Another option is to use the less secure IPSec method but the official fw doesn't support this....perhaps the Merlin's fw supports this? Unfortunately using each pc or device connected separately to OpenVPN or IPSec isn't really an option as i would like to connect to VPN at router level due to having > 3 devices in our home network (the VPN provider doesn't allow > 3 simultaneous connections from each IP)
Cheers
Cheers
