toaruScar
I've got this issue where the mDNS name of my router keeps changing or -should I say- increasing.
What do I mean by "mDNS name"?
One of my router's hostname is set to `ZenWiFi_XT8-Main`, so it's reachable at `zenwifi_xt8-main.local`, and this ".local" name is the mDNS name.
What is the problem?
As time goes by its mDNS name will gain a suffix like "-2" or "-3" and it keeps increasing slowly, so in order to reach it I need to access `zenwifi_xt8-main-2.local` and so on. (However the hostname `ZenWiFi_XT8-Main` is still accessible thanks to NetBIOS).
Also the following is in the log:
This keeps going on until the suffix reaches "-14".
Using a Bonjour browser, I can see that at this moment 2 of my 4 ZenWiFi XT8 are having this issue: the "Main" one and the "MaBedroom" one.
This is problematic for me because I use the router as a Time Machine backup server, and if the mDNS name changes, my Macs can't backup to the router.
Scope of this problem
This problem only occures on asus routers (currently on 3.0.0.4.386_25224-g3c383a4). Other devices in my LAN (including a printer, Macs running macOS Catalina, iOS devices running iOS 13.4) do not have this problem.
Workaround
One quick fix I can find is ssh into the router and run this command.
Is there a way to fix this once and for all?
avahi-daemon[1924]: Host name conflict, retrying with ZenWiFi_XT8-MaBedroom-2
avahi-daemon[1924]: Host name conflict, retrying with ZenWiFi_XT8-MaBedroom-3
avahi-daemon[1924]: Host name conflict, retrying with ZenWiFi_XT8-MaBedroom-4
Workaround
service restart_mdns
