mDNS on different subnets via VPN
Igor
Two local networks on two routers are connected via OpenVPN.
The routers have files "/jffs/configs/avahi-daemon.conf.add" with the following settings:
[publish]
publish-addresses=yes
publish-hinfo=yes
publish-workstation=yes
publish-domain=yes
[reflector]
enable-reflector=yes
After rebooting (service restart_mdns) I see new parameters in "/tmp/avahi/avahi-daemon.conf"
Then I add network permissions on the routers:
iptables -I FORWARD -i br0 -o tun+ -j ACCEPT
iptables -I INPUT -i tun+ -p udp --dport 5353 -j ACCEPT
But this didn't help me with mDNS forwarding to another local network.
What needs to be done to make mDNS used in different subnets connected via OpenVPN?
This is just a guess but,
1) I don't think you need any additional iptables rules as there should already be rules that do the same thing. I'm assuming you have a working bidirectional OpenVPN LAN to LAN setup.
2) I think you also need to add the following line to the [Server] section of avahi-daemon.conf :
allow-point-to-point=yes
That way, when either avahi-daemon or openvpn starts up you should see messages similar to the following in the syslog.
Mar 21 16:28:48 avahi-daemon[6624]: Joining mDNS multicast group on interface tun21.IPv4 with address 10.8.100.1.
Mar 21 16:28:48 avahi-daemon[6624]: New relevant interface tun21.IPv4 for mDNS.
Mar 21 16:28:48 avahi-daemon[6624]: Registering new address record for 10.8.100.1 on tun21.IPv4.
and
Mar 21 16:29:11 avahi-daemon[6624]: Joining mDNS multicast group on interface tun11.IPv4 with address 10.100.0.2.
Mar 21 16:29:11 avahi-daemon[6624]: New relevant interface tun11.IPv4 for mDNS.
Mar 21 16:29:11 avahi-daemon[6624]: Registering new address record for 10.100.0.2 on tun11.IPv4.
This could be a security issue though if you have other point to point network interfaces to untrusted networks, e.g. a commercial VPN service. In that case you'd probably have to add either allow-interfaces= or deny-interfaces=.
Thanks for your reply! Unfortunately, I missed your reply, sorry.
I added to the avahi-daemon.conf
[Server]
I use the command
cat /tmp/syslog.log | grep avahi
to look at the log. I see the entries you specified from avahi-daemon on all interfaces, including tunnels.
Next I started to analyze traffic on one host in the network 192.168.2.0/24
sudo tcpdump -e -vv -n port 5353 and net 192.168.1.0/24
But I didn't find any packages from another network.
Then I added to the config
[publish]
publish-hinfo=yes
publish-domain=yes
[reflector]
There is something I am missing or doing wrong.
I would run tcpdump on whatever device is running the VPN on 192.168.2.0/24 and monitor what's coming out of the tunnel interface.
[publish]
publish-hinfo=yes
publish-domain=yes
[reflector]
Just to be clear - you added both the allow-point-to-point option and the enable-reflector option?
Yes, I added it. Later I saw that my Home Assistant from one network saw devices in another network. Then I analyzed the traffic again and saw the necessary packets, the format of which was different from what I expected.
192.168.2.1.5353 > 224.0.0.251.5353: <...> (Cache flush) A 192.168.1.183, KD-43XD8305._androidtvremote2._tcp.local. <...>
In the end, two options helped - allow-point-to-point and enable-reflector. Thank you!
