Media bridge mode at 5 GHz
David Arnstein
Summary: I cannot get media bridge working on a 5 GHz WiFi network. 2.4 GHz is OK.
Media bridge is RT-AC68P with Merlin firmware 384.19 and 386.1. Problem exists in both firmwares.
Upstream router is RT-AX86U with Asus firmware connected (wired) to a cable modem.
I have tried two different 5 GHz SSIDs. The RT-AC68P (Merlin) accepts the SSID and reboots. After that, wired client can connect to the RT-AC68P for a few seconds and then becomes disconnected from the internet; client's IP address is lost.
Two different 2.4 GHz SSIDs work OK.
Is this a known problem? Would it help to go back to Asus firmware on the RT-AC68P?
Try setting the 5Ghz to low fixed channel like 48 on the main router.
