I have limited knowledge about routers. I have a router from my ISP (KPN Netherlands) handing out IP's 192.168.2.0 and I connected a Asus RT-AX88u handing out 192.168.178.0. I want to be able to merge the ranges so devices in either range can communicate with each other, is this possible? I tried to get rid of the KPN router and only use the Asus but I was not successful in that. I could get the internet to work but not my IPTV. please give a detailed explanation because answers like I've read on other forums like setup a vlan or setup a route is not enough. I don't know how to do that. Hopefully someone wants to spend time on this. If someone has KPN with IPTV working without the KPN router that is also fine (even better).
