Merlin 378.53: UDP Assured and Unassigned Values Not Changeable
pilotboy72
Hello,
I noticed on the Tools | Other Settings tab that the values for the last two items, UDP Assured and UDP Unreplied had values of undefined and blank respectively. I typed in the default values shown in yellow at the right of those fields and clicked apply.
Now when the page refreshes, I am seeing values of 6 and 1 respectively. I've tried repeating the default values and setting other arbitrary values but when the page refreshes I still see 6 and 1 for those values. The other fields on the page seem to respond correctly.
Can someone else verify if you see this same behavior?
Note that this is on the RC-AC3200. I only noticed this behavior after I had done a default reset (WPS reset) so I do not believe this is due to upgrading from .52.
Thanks,
Brian
Hello,
Thanks,
Brian
I can't reproduce the issue here. Check the current timeouts:
nvram get ct_udp_timeout
If they are corrupted, reset them to their default values:
nvram set ct_udp_timeout="30 180"
nvram commit
reboot
That seems to have worked. Thanks!!!
