KattinVN
Hi guys
My old router is AC3100 currently running 386.7_2 without issue
I decided upgrade it to Wifi6 so i choose AX68U, buy it from local store at china a few day ago
after received I flash merlin 386.7_2 but the router auto reboot randomly anytime ~every 1-3 hours
After few day check:
I hope @RMerlin can find out the bug
#1. Checksum SHA256 386.7_2 to verify file correct | still reboot randomly |
#2. Check power line | still reboot randomly |
#3. Factory default on webUI also tick "Initialize all the settings" | still reboot randomly |
#4. Not setting anything on router, only set SSID and password | still reboot randomly |
#5. Turn off setting on web interface i think it's the fault | still reboot randomly |
#6. A whole day no device connect to AX68U | still reboot randomly |
#7. Flash merlin 386.5_2 and factory reset | still reboot randomly |
#8. Flash merlin 386.5 and factory reset/not change anything on setting | currenly testing |
#9. Flash stock rom 386.49479 use same setting on merlin 386.7_2 | work perfecly fine |
