linkwellfook
Hi
I'm trying to set up Mulvad VPN and when I attempt to launch it I receive an error status of 2
I followed
however some settings I did not change
namely
In Lan -> DHCP Server DNS 1 and 2 are blank
Accept DNS configuration is set to Relaxed
I do not use IPv6
Below is the log
Googleing the error it was suggested on linux forums to restart the VPN servive.
Would this help in this case or is it something unique to the mullvad ovpn config?
I followed
Asus Merlin and Mullvad VPN
How to setup your Asus router running Merlin to connect to the Mullvad VPN servers.
mullvad.net
namely
I do not use IPv6
Below is the log
Running /jffs/scripts/service-event (args: start vpnclient1)
OpenVPN 2.5.7 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Dec 3 2022
library versions: OpenSSL 1.1.1s 1 Nov 2022, LZO 2.08
Running /jffs/scripts/service-event-end (args: start vpnclient1)
NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
TCP/UDP: Preserving recently used remote address: [AF_INET]<remote-address:port>
Socket Buffers: R=[87380->1048576] S=[16384->1048576]
Attempting to establish TCP connection with [AF_INET]<remote-address:port> [nonblock]
TCP connection established with [AF_INET]<remote-address:port>
TCP_CLIENT link local: (not bound)
TCP_CLIENT link remote: [AF_INET]<remote-address:port>
TLS: Initial packet from [AF_INET]<remote-address:port>, sid=96df95c0 14f745a2
VERIFY OK: depth=2, C=SE, ST=Gotaland, L=Gothenburg, O=Amagicom AB, OU=Mullvad, CN=Mullvad Root CA v2, emailAddress=security@mullvad.net
VERIFY OK: depth=1, C=SE, ST=Gotaland, O=Amagicom AB, OU=Mullvad, CN=Mullvad Intermediate CA v5, emailAddress=security@mullvad.net
VERIFY KU OK
Validating certificate extended key usage
++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
VERIFY EKU OK
VERIFY OK: depth=0, C=SE, ST=Gotaland, O=Amagicom AB, OU=Mullvad, CN=<server_location.mullvad.net>, emailAddress=security@mullvad.net
Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA256
[server_location.mullvad.net] Peer Connection Initiated with [AF_INET]<remote-address:port>
SENT CONTROL [ie-dub-002.mullvad.net]: 'PUSH_REQUEST' (status=1)
PUSH: Received control message: 'PUSH_REPLY,dhcp-option DNS 10.5.0.1,redirect-gateway def1 bypass-dhcp,route-ipv6 0000::/2,route-ipv6 4000::/2,route-ipv6 8000::/2,route-ipv6 C000::/2,comp-lzo no,route-gateway 10.5.0.1,topology subnet,socket-flags TCP_NODELAY,ifconfig-ipv6 fdda:d0d0:cafe:443::1000/64 fdda:d0d0:cafe:443::,ifconfig 10.5.0.2 255.255.0.0,peer-id 0,cipher AES-256-GCM'
OPTIONS IMPORT: compression parms modified
OPTIONS IMPORT: --socket-flags option modified
OPTIONS IMPORT: --ifconfig/up options modified
OPTIONS IMPORT: route options modified
OPTIONS IMPORT: route-related options modified
OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
OPTIONS IMPORT: peer-id set
OPTIONS IMPORT: adjusting link_mtu to 1627
OPTIONS IMPORT: data channel crypto options modified
Data Channel: using negotiated cipher 'AES-256-GCM'
Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
GDG6: remote_host_ipv6=n/a
net_route_v6_best_gw query: dst ::
net_route_v6_best_gw result: via :: dev lo
TUN/TAP device tun11 opened
TUN/TAP TX queue length set to 1000
/usr/sbin/ip link set dev tun11 up mtu 1500
/usr/sbin/ip addr add dev tun11 10.5.0.2/16
Linux ip addr add failed: external program exited with error status: 2
Exiting due to fatal error
