Hi Guys,
Thank you Merlin for all your hard work and excellent firmware.
A little background:
I'm coming from N66U (which run shibby's tomato, I guess you can say I'm a tomato guy ). My household is fully wired cat5e/cat6 and I don't rely much on wifi... other than kids ipads, cell phones to check email/browse the net. I guess I'm a dinosaur
I bought AC1900P router to help with WAN-TO-LAN speeds on my new 1GB internet service. With N66U tomato (NAT acceleration) disabled I was maxing at 150mb. With Merlin/Asus fw NAT enabled from my understanding I could get 200mb-250mb max.
I did flash the new router with the latest AC68 fw without any issues.
I started populating the settings last night (run out time to finish it) I really like the options Merlin fw offers, however it is a little different from shibby's tomato. I still need to make some changes. I love what AI Protection offers for my 2 kids with laptops and ipads.
Since I'll be doing one for one router swap, I have to wait till all family goes to sleep for any sort of testing. LOL
I have few questions.
- ssid for 2.4ghz and 5ghz networks, different or the same? I see mixed opinions... BTW... I was using only 2.4ghz on my to-be-retired N66U.. Should I even bother with 5Ghz if I was happy with 2.4Ghz.
- for guest network, should I create two 2.4ghz and 5ghz variants or one 2.4ghz is good enough?
- for guest network, should I bother with MAC filtering?
- is there a way to turn off wifi radio for specific period of time? (shabby tomato - had it under access restrictions)
I will revisit all the options again tonight to make sure I haven't missed anything.
Thanks in advance for your input and help !
Martin
Martin
