Darrin Reed
I am new to linux and have no idea how to fix.
Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012
NAND device: Manufacturer ID: 0xc8, Chip ID: 0xd1 (Unknown NAND 128MiB 3,3V 8-bit)
Spare area=64 eccbytes 56, ecc bytes located at:
2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Available 7 bytes at (off,len):
(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Scanning device for bad blocks
Bad eraseblock 1000 at 0x000007d00000
Bad eraseblock 1009 at 0x000007e20000
Options: NO_AUTOINCR,NO_READRDY,
Creating 1 MTD partitions on "brcmnand":
0x000004000000-0x000008000000 : "brcmnand"
VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
devtmpfs: mounted
Freeing init memory: 288K
rtl8365mb: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
rtl8365mbrtl8365mb initialized(-1)(retry:10) failed
rtk port_phyEnableAll Failed!(-1)
devtmpfs: mounted
