Im having with create, move and write access issues on USB drive except delete file. Every restart, it was working but up to 5-10 minutes. It went stop write or creating new file/folder. It giving error like “Operation not supported” then i check system log here:
Do i go downgrade firmware? wait for next version? What do i do? Need help...
Apr 13 11:54:22 kernel: __ntfs_error: 5 callbacks suppressed
Apr 13 11:54:22 kernel: tntfs error (device sda2, pid 4421): ntfs_mft_data_extend_allocation_nolock(): Not enough space in this mft record to accommodate extended mft data attribute extent. Cannot handle this yet.
Apr 13 11:54:22 kernel: tntfs error (device sda2, pid 4421): ntfs_mft_record_alloc(): Failed to extend mft data allocation.
Apr 13 11:54:22 kernel: tntfs error (device sda2, pid 4421): ntfs_create_helper(): Failed to allocate a new on-disk inode (error 95).
Apr 13 11:54:22 kernel: tntfs error (device sda2, pid 4421): ntfs_create_helper(): Failed (error 95).
Apr 13 11:54:22 kernel: tntfs error (device sda2, pid 4422): ntfs_mft_data_extend_allocation_nolock(): Not enough space in this mft record to accommodate extended mft data attribute extent. Cannot handle this yet.
Apr 13 11:54:22 kernel: tntfs error (device sda2, pid 4422): ntfs_mft_record_alloc(): Failed to extend mft data allocation.
Apr 13 11:54:22 kernel: tntfs error (device sda2, pid 4422): ntfs_create_helper(): Failed to allocate a new on-disk inode (error 95).
Apr 13 11:54:22 kernel: tntfs error (device sda2, pid 4422): ntfs_create_helper(): Failed (error 95).
Apr 13 11:54:22 kernel: tntfs error (device sda2, pid 4420): ntfs_mft_data_extend_allocation_nolock(): Not enough space in this mft record to accommodate extended mft data attribute extent. Cannot handle this yet.
Apr 13 11:54:22 kernel: tntfs error (device sda2, pid 4420): ntfs_mft_record_alloc(): Failed to extend mft data allocation.
