Merlin firmware OpenVPN obfuscate
chichow
Merlin
Silly OpenVPN question
please see this thread
https://forums.openvpn.net/topic12605.html
Do I simply need to change the server config and client config file to xor or reverse data packet order? or I am still required to patch the OpenVPN pkg running on the asus merlin firmware?
some prior links regarding OpenVPN and China
http://www.snbforums.com/threads/wh...uration-for-openvpn-server.16907/#post-117079
http://www.snbforums.com/threads/openvpn-and-ssh-tunnels.22744/#post-166086
Thanks!
I haven't applied the scrambling patch. If you want to use it, you can take a look at Asuswrt-Phantom, a form of my firmware that has the patch applied.
I am thinking does using of additional TLS-AUTH can be effective against DPI on OpenVPN? If the answer is YES it is much better solution.
