Merlin-IP Adresss not updating
BumpShot
Hi Merlin,
Just want you to see this.
The IP Address does not update in the connection Status window. ( middle )
But, it does update in the window on the right.
I have refresh the webpage over 5 times. And I also changed my IP address 2 times.
But, it is still the same.
The middle window does not update
the right side does update
As you can see the bottom of my browser shows the real IP address
Hi Merlin,
Must be some cacheing on your end, because it works fine here. I changed my WAN IP, and the new one showed on both location.
Also, both location retrieve the IP from the exact same function call (wanlink_ipaddr();).
I cleared my browser cache. Tried waterfox, IE, and firefox. They all say the same. Also tried looking from 3 computers.
I also re-flashed the 378.52_2 version .
I then changed my Ip again.
I get this.
It does not stop me from using it.
It works fine.
Just reads out wrong.
That IP in the middle was from 2 days ago.
I'll Have to try to re-flash it back to 378.52 and see if it changes.
Ok, I re-Flashed it with 378.51 . it work fine and changes every time ( Changed IP address 5 times. )
Then flashed it with 378.52. The IP stuck. Did not change. ( changed IP adress 5 times )
Even has the same IP as the Last Flash.
I re-Flashed router
after Flash , I rebooted router
I rebooted Modem
Cleared cache
and waited for it to come up.
Can you telnet/ssh to the router and post the output of the following commands (of course, filling in the real addresses)
nvram show | grep <bad-ip-address>
nvram show | grep <good-ip-address>
